WOOHOO!!! - not anymore :(
my car works!
started first time (after turning it over without the fuel pump fuse till the clattering stopped) ran sweet as, all the gears appear to be there, the clutch is pretty much perfect (i'll make it 100% later)...and the speedo works!
anyone in maidenhead wanna come and help me put the bonnet back on? cant' really do it on my own!
[ Edited ]
ok...its not right
when i drove round the estate with no bonnet i was only at low rpms and low throttle...it felt fine.
now i've got the bonnet back on and took it for a proper spin alls not well. theres no power...feels a bit like its not on all cylinders. the clutch makes a weird noise that goes away when i press the pedal.
ideas please? i haven't checked for sprks yet as i was fed up and needed something to eat...will crack on with it tomoz morning...give me things to check
sorry to hear that mate :( the clutch noise could be your thrust bearing.....................as for a lack of power...if you've got a spark on all cylinders then i'd do a compression test...and take it from there really!
[ Edited Fri Jul 30 2004, 09:42PM ]
timing is possible..........did you set the car up your self or do you have a timing light so on.......i'm only speaking from my experience with 8 & 16v golf's so the vr may be a bit different. when ive had to set my 8v after a new cam belt, you can feel the difference as you advance the timing while on a road test!
Andy theres a guy called B Simmons located down by the River, he's a VW audi specialist. My brother takes his Gti there, he might be able to help, i'll try and get his number if you want. (his ad is in the M'head advertiser too)
