billy111 0 Posted March 28, 2007 Report Share Posted March 28, 2007 What is a reasonable charge to have a sports suspension fitted? I have bought a Pi kit (35mm) non-adjustable. I have been quoted from £270 - £400 to have it fitted, which I think is too high. I was budgeting on £150-180 (including wheel alignment etc).Also can anyone recommend a good garage in the cambridgeshire/suffolk area? Link to post Share on other sites
kalv 0 Posted March 28, 2007 Report Share Posted March 28, 2007 It's the labour thats going to roger you.. me and my old man replaced mine with uprated ones and took us about 2.5/3 hours.. garage will take about 4 minimum (tea break/chit-chat/etc..)... even on £45/hour labour (which is a good rate)... your looking around £180.. could get it cheaper if paying by cash?I paid around £35 for 4-wheel laser alignment with camber/toe adjustment... so you total will be over the £200 mark! Link to post Share on other sites
vr6madmike 0 Posted March 28, 2007 Report Share Posted March 28, 2007 Try having ago yourself with a mate, its really quite simple there is a guide on here too. Link to post Share on other sites
xyber 1 Posted April 9, 2007 Report Share Posted April 9, 2007 Yep i did mine easily enough, if you do, give the nut on top of each turret a good soak in WD40 the night b4 as they can be abit tight and rustedAlso replace all bump stops, bushes and bearings whilst its out, only a couple quid from GSF and worth it in the long run, also get the suspension adjustments done at a garage straight away after or it'll eat the tyres well quickly Link to post Share on other sites
