steveg60cab 0 Posted January 27, 2007 Report Share Posted January 27, 2007 i've only had my vr for a week, and due to an oversight of a lack of antifreeze, there's now a pinhole in my rad!!!!a new rad has got to go in, but looking at the 'bay, there's not a lot of room between the inlet manifold and the slampanel...so how do i get the bugger out?? inlet manifold off job?btw, it's a '96 golf Link to post Share on other sites
thegoth 5 Posted January 27, 2007 Report Share Posted January 27, 2007 Welcome to the wonderful *-) world of VR6 ownershipI don't know the exact details, but in brief, AFAIK, you have to take the front of the car off!TG Link to post Share on other sites
steveg60cab 0 Posted January 27, 2007 Author Report Share Posted January 27, 2007 Welcome to the wonderful *-) world of VR6 ownershipI don't know the exact details' date=' but in brief, AFAIK, you have to take the front of the car off!TG[/quote']this is what i'm dreading!! please someone else tell me otherwise!! Link to post Share on other sites
craggsy 91 Posted January 27, 2007 Report Share Posted January 27, 2007 front off im afraid!!!If you have air con makes it a bit trickier Link to post Share on other sites
Kaz 0 Posted January 27, 2007 Report Share Posted January 27, 2007 It's not that big a job, un-clip the grille, take the head lights out, then it's 6 or 7 10mm bolts to take the bumper off. Then you have to remove the metal part of the cross member first, this is held on with 4 13mm bolts, then you can take the plastic slam panel off this holds the radiator, so you'll need to un-clip all the hoses before you can remove it - and the rad will come away with it. It's 2 bolts on the wing, and 4 or so that hold the metal part to the plastic part. Link to post Share on other sites
craggsy 91 Posted January 27, 2007 Report Share Posted January 27, 2007 BUT if he has aircon then to take front off he will need to degass the air con........i know ive done it Link to post Share on other sites
steveg60cab 0 Posted January 28, 2007 Author Report Share Posted January 28, 2007 AAAAAAARRRRRRGGGGGGHHHHHH!!!!!!!!!!!!!!!!!!!!!i'm gonna sit in a corner and cry now, lol!!!cheers for the advise guys, i'd have been scratching my head for days on how t otackle this one other wise!!so why can't i just take the inlet manifold off and bring through that way?? Link to post Share on other sites
Petesvw 0 Posted January 28, 2007 Report Share Posted January 28, 2007 Ok, bit of a stab in the dark, but if you jack the car up and put it on axle stands, are you not able to disconnect the water rad and slip it out without removing/disconnectint the air condensor? Link to post Share on other sites
steveg60cab 0 Posted January 28, 2007 Author Report Share Posted January 28, 2007 it hasn't got air con, thank god!! Link to post Share on other sites
clarkie 1 Posted January 28, 2007 Report Share Posted January 28, 2007 just take the fromt off mate. will take an hour 2 change at the most. easy job Link to post Share on other sites
steveg60cab 0 Posted January 28, 2007 Author Report Share Posted January 28, 2007 clarkie, you've made me feel much better about it now!!you lot must think i'm useless, but i did build my g60 cab myself a couple of years ago, i just can't be arsed these days!! lol Link to post Share on other sites
Kaz 0 Posted January 28, 2007 Report Share Posted January 28, 2007 Ok' date=' bit of a stab in the dark, but if you jack the car up and put it on axle stands, are you not able to disconnect the water rad and slip it out without removing/disconnectint the air condensor?[/quote']There isn't the room to slid it out - the cross member it sits on is too wide.It's easy to do, just give it a go.. Link to post Share on other sites
