baz8328 0 Posted December 11, 2006 Report Share Posted December 11, 2006 My car has been stood for about a month and i have just noticed a very wet footwell under the passenger seat !!Its wetter than a otters pocket !!!Can anyone help ! I cant see where water is comin from and it keeps gettin worse !!PLEASE HELP AS I AM GOIN TO PUT A MINT INTERIOR BACK IN AND DONT WANT IT GOIN MOULDY Link to post Share on other sites
gav_113 0 Posted December 11, 2006 Report Share Posted December 11, 2006 could have a leaking door seal? hole in the floor? or even a fucked heater matrix? i would take the carpet up, dry the floor, and check to c where the water is coming from? Link to post Share on other sites
Crasher 0 Posted December 11, 2006 Report Share Posted December 11, 2006 Usually this is the heater air inlet ducting leaking around its base and is quite easy to fix once you have it stripped down. The new gasket is 1H0 819 166 and costs £2.89 inc. VAT from VW. Also, a poorly fitted or cracked scuttle trim can allow water to poor into the pollen filter. Link to post Share on other sites
baz8328 0 Posted December 11, 2006 Author Report Share Posted December 11, 2006 i have removed the scuttle panel to fit single wiper mechanism . could this cause the carpet behind the passenger seat to become wet Link to post Share on other sites
baz8328 0 Posted December 11, 2006 Author Report Share Posted December 11, 2006 its the footwell behind the passeger seat !! Link to post Share on other sites
baz8328 0 Posted December 11, 2006 Author Report Share Posted December 11, 2006 i will have to check door seals!!any other advice Link to post Share on other sites
jezmoz 0 Posted December 11, 2006 Report Share Posted December 11, 2006 I have the same problem the footwell behind the passenger seat in the rear, i think it's coming down the b pillar from the sunroof?? Link to post Share on other sites
jezmoz 0 Posted December 11, 2006 Report Share Posted December 11, 2006 and there is no water in the front of the car just the rear footwell so it must be coming in that area , either door membrane door seals or sun roof , i think it's the latter as I saw a bead of water run out of the b pillar directly above the footwell. Link to post Share on other sites
lee060 3 Posted December 11, 2006 Report Share Posted December 11, 2006 check sunroof drain channels . could be blocked?? Link to post Share on other sites
c4mbl 1 Posted December 11, 2006 Report Share Posted December 11, 2006 i had the same problem and it was the sunroof that was leaking, i plugged the hole and still have to clear the drain channel. Link to post Share on other sites
jezmoz 0 Posted December 11, 2006 Report Share Posted December 11, 2006 best way to unblock them??? Link to post Share on other sites
Bigjobbo 0 Posted December 11, 2006 Report Share Posted December 11, 2006 get an air line and blow em through. If not strip it and water test it. Link to post Share on other sites
baz8328 0 Posted December 11, 2006 Author Report Share Posted December 11, 2006 blow what out ??? Link to post Share on other sites
lee060 3 Posted December 11, 2006 Report Share Posted December 11, 2006 BLOW WHAT OUT sorry but im full of man flu so not to bright tonight Drain channels mate . Link to post Share on other sites
