About jscaml
Meriden, Coventry
loud exhaust and vibration at idle
jscaml replied to jscaml's topic in Engine Maintenance and Problems
Thanks for the replys guys, but the thing i didnt make clear before is the exhaust is louder at the end of the tailpipe. I cant hear or see any leaks along the system. Is it likely its still just a really small hole in the exhaust or could it be summit else? Btw the vibration is bad at idle and acceleration but when engine braking it goes completly -
driving along the a46 today at a healthy ton, the vr all of a sudden sounded different. it got a deeper note from the exhaust naturally i slowed down a bit but nothing else seemed wrong as i tried to accelerate again it feels low on power and when im stopped at lights etc. i can feel the steering wheel vibrating. bit worried cuz im workin 7 days a week at the mo so cant really get to a garage. any1 got any good ideas what this might be?
best race ever yesterday, sum one has to stop vettel tho he's starting to annoy me.
just trying to remove the aircon on my vr got the condensor off, got a new non aircon belt from gsf went to fit it and it's longer than the original. thats not right is it? and how does the new belt route is it the same just missing out the air-con any info appreciated cheers guys
brake caliper bolts rounded off..
jscaml replied to caretaker's topic in Wheels, Brakes, Suspension and Steering
If anyone else has this i found these really usefull http://www.machinemart.co.uk/shop/product/details/5-piece-bolt-grip-set -
Coilovers, which to get??
jscaml replied to VR6Wherry's topic in Wheels, Brakes, Suspension and Steering
don't know how good they are but JOM do stupidly cheap coilovers -
just sprayed and fitted two new front wings so definatly don't want to be doing that, I used 15psi worked fine.
definatley I might do the brakes with it next, the fluid I got out the clutch looked like treacle so probly for the best.
Paint Shops / Body Shops in West Midlands?
jscaml replied to adam_christie's topic in Bodywork and Styling
try autosurgery on lockhurst lane in coventry just had two new wings and both rear quaters sprayed on my vr good price and good finish http://www.autosurgery.co.uk/ -
the eazi bleed works a treat costs £20 from halfords if your havin trouble bleeding yours then I definatley recomend it
Got an easy bleed now that uses pressure from the spare tyre, hope that fixs it.
okay guys, just tried to bleed my clutch it was working alright except the pedal didn't always return to the top of it's travel, I had a new slave cylinder and clutch about 6 months ago and was told that somtimes that that happens and it just needed rebleeding. But now i've tried to bleed the pedal only comes back up a couple of inches and i can't engage gears what have I done wrong? was using an visibleed with a 1 way valve on the end and getting missus to press pedal while I opened and closed the bleed nipple. Any ideas welcome tah.
My stock Golf MK3 VR6 2.8 could use a little more power
jscaml replied to Stonedizzy's topic in Engine Tuning
yeah the bmc cda sounds wicked btw -
Cheers guys, now I just need sum good weather to fit them
Just got some new headlights from gsf, but they take a different sidelight bulb than the standerd ones the main plug in the back of them fits and they look like they should fit in the car fine. Any idea's why this is and if it would cause a problem? Cheers
