Puto do Polo
About Puto do Polo
Portugal
Like topic need a couple of 100mm push in flanges from CCM or other, decent shape. the seller has to ship to Portugal Best Regards
I've mine wrapped and i lovit, the tempreture is much lower in engine bay, and exhaust loose heat much more slower! i recomend
speedometer stoped working...
Puto do Polo replied to lomikaar's topic in Engine Maintenance and Problems
i had this problem, in my case is the plug on the gear box was dirty. -
Hello, I've done the search and not find what i'am looking, need help! in pass i have some wire problem on my 95 Vr6 and replaced the relay\fuse box, but now in vag com apear "Oxygen sensor error" i mesure the wire and i have not 12v on the O2 heater, the fuses is fine (fuse 18 i think), where i find, or where is locate the O2 Heater relay? Tanks for the help! Best regards from Portugal
Climatronic Air Con unit causing car to cut out
Puto do Polo replied to sadken's topic in I.C.E, Security an Electrical
hello, normaly when this happens is the AC compressor is dead, stuck. whe the cluch is on the motor those not have strenth to turn over the compressor and the motor cut out! -
My Vr6 chokes at 5500rpm
Puto do Polo replied to Puto do Polo's topic in Engine Maintenance and Problems
Yes, i already do the ecu reset and still the same.. -
Hello, i'm have a 4 pot porsche calipers on my Vr6 with 312mm discks with textar pads and new hoses all round and, i'm disapoited with it.. i think i possibily have a problem with my master cylinder, my question is.. Can i put a larger master cylinder? if yes which one?which size is OEM? Best regards
Alex22 taknks for your help! yes, i think the "short to ground" is a wiring problem, but i don't know where is the "Gear Monitoring Switch (F209)" or what is it! Oxygen sensor i think is the Lanbda sensor correct? best regards -
No one..? -
Hello people, i need some help, my golf vr6 is OBD1 95 2.8 is doing a litle choke, like a missfire at 5500rpm, i turn on my vag com and it's wired error.. 2 Faults Found: 00525 - Oxygen Sensor (G39) 03-10 - No Signal - Intermittent 01152 - Gear Monitoring Switch (F209) 31-00 - Open or Short to Ground i already change my oxygen sensor, and stays the same, and the two erros apear at the same time.. the second error i dont have any clue.. anyone? tanks
