AxlFoley
About AxlFoley
uranus
The tappets on my VR have been noisy since i drove a bit quickly through a big puddle, but lately they are getting even more noisy, I am looking to replace them, the question is where from? Should i bite the bullet and get them from VAG, or are there cheaper options that are just as good ? Thanks in advance Mark
My mk3 VR6 has recently started burning behind the dash, a few times I have had smoke coming from the steering colum on start up. But no always. Just wondering if anyone else has had this, any common problems on the MK3? Thanks Mark
Bealieboy reacted to a post in a topic: Oil catch tank
I'm am looking into fitting an oil catch tank on my VR from the cam cover to remove the PCV Tube. I am just looking for a bit of guidance as to the best tank and if possible some photos of your tanks and locations.
VR6Pete reacted to a post in a topic: Genuine Dog Guard
I'm on the look out for a genuine VW Dog guard for a hatchback if anyone has one lying about. Thanks Mark
my VR started making a very bizarre grumbling noise, that sounds like its coming from near the gearbox. when I drive normally, there is no noise, but when I change gear there is a small grumble,I can feel it through the clutch pedal, and again if I put it in neutral, at first I thought it was a loose wheel, but they are all fine, all bearings are also fine. I noticed there is a small amount of play in the gear box drive shaft flanges, could this be a cause? I haven't checked the drive-shafts are bolted up tight, so will do this tomorrow, but they look ok. anyone got any ideas as to what
Bealieboy reacted to a post in a topic: mysterious water loss
there is nothing obvious there, although there is some water marks near the expansion tank, but I have put this down to a water pipe blowing a wile back, I think a full engine bay clean and de-grease is in order, that should help spot any new leeks.
could be the rad cap, oil cooler is new and water tight. I think the rad cap has to be worth swapping for a new one.
carpets are dry as a chip! that's what I thought at first too.
I have a VR6 golf that has a bit of a hydration problem, I cant seem to keep the water in the engine. there are no signs of leeks, if I run it stationary, there is no evidence of water loss, but it needs a top up after a few days of driving. I have swapped the thermostat housing and oil cooler, but this hasn't helped, there is no mayo in on the oil cap. Any ideas? on another note, recently the dash wont show the outside air temp, could this be connected ? Thanks Mark
To be honest I thought the replacement plastic one would be more expensive than they are, I think I'll stick with plastic, thanks for finding the alloy one though Sent from my iPhone using Tapatalk
I'm sure I have seen somewhere that you can get a billet thermostat housing to replace the crappy black plastic one, does anyone sell them in the UK? Thanks Mark Sent from my iPhone using Tapatalk
Outside air temp sensor part number
AxlFoley replied to AxlFoley's topic in I.C.E, Security an Electrical
Nice one, thanks Sent from my iPhone using Tapatalk -
My outside air temp sensor, the one that fits in the bumper seems to have dissapeared! does anyone know the part number so i can get a new one? if anyone has one for sale I would be interested too. Thanks Mark
Engine hunting and cutting out
AxlFoley replied to AxlFoley's topic in Engine Maintenance and Problems
I have narrowed mine down to the LPG conversion, its fine on petrol, good luck with the fault finding. -
VR6Pete reacted to a post in a topic: Engine hunting and cutting out
will do, thanks.
