jimphudson
About jimphudson
leeds
bolt in middle of rear break disc.
jimphudson replied to jimphudson's topic in Wheels, Brakes, Suspension and Steering
Thanks so much mate really appriciate that -
I tried to jump in on someone elses thread for an answer but failed.I am about to change rear discs, pads and bearings.I spoke to someone about the way to do it they said there would be a bolt or nut in the middle of the breakdisck to hold it on( a fairly big one). If this makes sense does anyone know the size as Ill have to get bthis before I attempt it. cheers all
Alright mate I am no expert but i fitted samco hoses to my car I had 7 but only fitted the 5 you have pictured can not find the other 2 for the life of me. they are fairly streight forward to work out which goes where when your taking the old ones out. good luck with it. If yo find where the last two little ones go let me know mate.
Thanks very much mate I had missed the 8mm screw. I had undon the three for the locking mechanism but missed that one. The pin took some bending to get it in the right position for the hook on the polo mk4 handles, did you have to bend your pin ass well. CHEERS MATE
hey all im probably been thick but how do you remove the door handles I have some polo mk4 ones to put on but can not get the old ones off any help appriciated thanks.
Think im going see you ther
Thanks mate followed the instructions you gave went really well thanks mate
thanks mate not the best when it comes to technical ish stuf will ollow what you say. setting about it tomorrow morning
as the title sugests how do you remove the front seats got new leather recaros to go in any ideas on my last post about the front door locks also much appriciated. cheers for any ideas
alright all the handle on the passenger side of my vr (97 eleci windows) does not open the door.I managed to get it to open to look at the lock, but can not get it out as there is a metal runner running from top to bottom with a silver wire behind it. the bar is held on by two 10mm nuts undid them but the bar would not move so can not get the lpock out. tryed putting it back together and the nuts will not go back. Any help with either prob welcomed i know its probably real simple but i cant work it out.cheers
Alright all just wondered if anyone can shed some light on this for me. I have some porsche boxster wheels to put on my car the fronts are 7x 17 et55 the rears are 8.5x17 et 50 i had a look on the calculator at the top of this page and got back inner clearance 34mm less and outer extended 4mm and the fronts inner clearance 20mm less and outers retracted by 20mm. I guess this means I need 20mm adapters on the front what would you recomend for the backs 30mm or 35mm anyone done this and knows any advice would be great cheers all sorry for rattling on just want it perfect first time.
cheers for that mate looks like a job i cant do might have to send it to the body shop.
Wanted to smooth the boot of my car does anyone have any advice or tips how to go about this. Like how is the rear spoiler attatched and the best way to remove it. also does anyone know where to get the gromits from to blank off the rear wiper hole. Any advice muchly appreciated. Cheers
alright mate just had lead and spark plug problems myself messed about getting cheap leads and still had the problem ended up getting bosch spark plugs and dubpower 7mm leads car has never run as well leads were only 40 pounds cant recomend them enough. good luck bud
