you are way off!! the caravelle has many differences.. it was desigened to have torque a lot lower down the rev range.larger cams will not fit!! even standard golf cams dont fit. if its a automatic (as most are) forced induction wont work as the gearbox is ecu controlled and has a map sensor and that works on manifold vacume, so every time you go into boost it changes to top gear thinking there is no load..apart from that the gearboxes are made of mush and can only just handle standard power.some of the other things that are different are small boar inlet manifold and longer. the cams are sing
