Matt82_16v
About Matt82_16v
southend essex
sure the hub nut is tight enough?
help please....... running issues
Matt82_16v replied to Biggazvr6's topic in Engine Maintenance and Problems
Not got access to Viacom so you can check before you replace? -
battery light flickering on and off now!
Matt82_16v replied to paceo's topic in Engine Maintenance and Problems
dying alts can behave really strange. id just change it -
i said its greif... the splines on the outer cv are serrated and there is rumour that they glue them for the factor. caused a right drama on cgti years ago lol machine mart sell a hub tool that worked on mine but i killed the tool on the first use dont twaat the cv too hard, youll damage the thread http://www.machinemart.co.uk/shop/product/details/cht464-front-hub-puller?da=1&TC=SRC-hub
unbolt the inner cv flange bolts hub nut ball joint clamp remove cv from hub on the inner cv there should be a circlip (as described). remove the boot clamps and then "hammer" the inner cv off the shaft there is a convex washer in there, most kits include a new one, but pay attention to which way it goes et voila (removing the outer cv from the hub can be a PITA to do)
Complete Refill Of Power Steering Fluid
Matt82_16v replied to vr6_super's topic in Wheels, Brakes, Suspension and Steering
id buy two bottles. one to flush, one to fill, considering its an item that is almost always neglected.
