Hellraiser
About Hellraiser
Antwerp, Belgium
Hellraiser's VR6 -> Other rims...
Hellraiser replied to Hellraiser's topic in Members Rides and Event Photos
Thanks! Had to sell the VR because I was a little bit tired of all my ongoing projects (beetle, golf, passat) that I decided to sell the lot and buy something else. Didn't know that I coud store so many parts in one garage, it looks like a dancehall now But I'm very sure that I'll buy myself a VR again, one day... -
Hi lads, sorry to say I've sold my VR... ... but something new came up Greetings, -
There was rust, now there's primer The car's a project and I hope to finish it against next summer -
Nope :-p Think the standard GT-rims look better under the VR, and a lot easier to clean :-p -
Hello, Before: After: 8-|
Hint of Blue Smoke From exhaust - Update
Hellraiser replied to kcw's topic in Engine Maintenance and Problems
this http://www.pagershop.nl/product_info.php?products_id=605&osCsid=56aa1e5471ae2bb69cde414d9a87da6e is the direct link. Don't cost much either, Only 20€ for models after 1993 and about 40€ for models before that year because they still have the 4-pins connector. -
I bought it from www.obd2shop.nl it's a dutch online shop. They deliver the cable and a free trial version of VAG-COM. I found a fully registered version of VAG-COM via TorrentSpy. Greetings, Johan -
I'm in the same situation at the moment, little bit of smoke when the car is idling, and started to misfire a few days ago but had some lack of maintenance, so going to do an oil change and replace the plugs and leads also bought myself a 2nd hand laptop (Dell Latitude CPx) and waiting for my OBD-cable and VAGCOM. -
Nice!
NGK BKR5EKUP
If it's warm it's below the minimum, and when it's cold, it's just under the max. *-)
The manual said to check after a few minutes when the engine was still warm... *-)
1992 All original, Dusty Mauve
How long do you have to wait to check the oil level after the ignition is turned off? So, I wait for about 15 mins to check it, and find the level 2 mm below the minimum. I'm a little bit scared, so I fill it to about 1 mm under the max. I put the car into the garage, and the next day I take a look again at the level, and suddenly it's about 3-4 cm's above the max... *-) Ow, and how much oil should there go in? is it 5 liters without the filter change and 6 including? Thanks!
