ringosnose
Everything posted by ringosnose
I want a code reader for crimbo from me wife.I was looking at this one http://www.talktomycar.co.uk/products/codereaders/MaxiScanMS309.htm Do you recon it will be ok for my 97 vr6
yup its normal
Pinking noise seems to be coming from the righthand side of the engine just behind the timing chain housing
Electrical Whine coming from the engine
ringosnose replied to Rsjvr6's topic in Engine Maintenance and Problems
I thought all vr6 whined when cold mine does then goes when the engine gets warm. -
losing coolant through breather on header tank
ringosnose replied to rusty dan's topic in Engine Maintenance and Problems
Narkered thermostate making coolant boil over? Air in the system? -
No not yet. The thing is if i have the window up the only way i would tell there was a missfire is that when i take my foot off the accelarator theres a little jolt,if i have the window down all i can hear is t.t.t.t.t.t.t.t. I havent noticed a loss of power however i think i may have just gotten used to the way it runs. going to try some redex and change the fuel filter then maybe clean the throttle body. McPikie if it were the case i was losing compresion how much does this cost to put right?
new pack fitted still missfiring??!!! WTF??!
idleing and staling probs still!!!
ringosnose replied to loubyvr6's topic in Engine Maintenance and Problems
i had this and it was the maf that was at fault vag com didnt show any faults for it,it was blaming the lambada for the stalls.Changed the maf and there were no fault codes at all and stopped the stalling. -
Replaced the 2 dodgy looking plugs still popping. looks like a new coil pack then !
The sealy tool works a treat. Checked the spark plugs before shelling out for a new coil pack and found that on cylinders 4-6 the plugs have gone brown around the base of the ceramic part of the plug.I suppose this is from not having the ht leads seated properly should i replace these two plugs?
Found one http://www.pvrdirect.co.uk/productinfo.aspx?catref=VS5293
Hi there replaced my ht leads because of the disco effects that they were making under the bonnet and also made the missfire realy badly p-p-p-p-p-pink. Anyway after checkin all the plugs were still tight i put my new magnercor leads on and im still getting missfire? the spark plugs are ngk platinums that have done about 5k and the coil pack seems fine no cracks or anything. The only thing i can think of is that the plastic lead remover tool isnt seating the leads properly as when you push the plastic tool just slips over the notches on the ht lead. So i recon i need a metal remover tool there
Sorry to open up a old thread but iv found someone that does adjust camber local to me and maybe some of you guys aswell http://www.merityre.co.uk/tyres-highwycombe.htm Cost me £55
someone local and anyone who can do a diagnostics test
ringosnose replied to vdubz's topic in Engine Maintenance and Problems
Same thing cheaper http://www.talktomycar.co.uk/products/codereaders/mj001.htm -
Have a look at this site for code reader seems to be some good stuff on there http://www.talktomycar.co.uk/index.htm -
My 97 Vr's idle is a bit erratik starting the car from cold the revs shoot up to around 2000rpm for around 3 secs then drops to around 1500 after about a minute or so this drops down to around 900rpm, If i put some revs on then take my foot off the accelereter the revs go back upto 2000 again then drop slowly back down to 900.You know how old ppl drive the cars not moving and the there reving the crap out of the car, thats probly what it look like to anyone watching me reverse out of my drive. Anyhow when the cars warms up the problem goes . I have searched the forum for some idea and have com
isnt there an over ride key for it? mine used to be in the glove box
It can happen if the leads arnt seated properly on the spark plug,The standard plastic lead tool on the bonet stay is ok for taking leads off but isnt the best for for putting them back on.Borrow or buy a metal version theres some links on the site somewere to some supplers of them.
yeah an authorised bosch garadge, you want to find your local one have a look here http://www.boschautoparts.co.uk/csMain.asp?c=4&d=1
That link dosnt want to work This would be the place though http://www.protyre.co.uk/slough.php cheers for ya help
Took it to a bosch garadge they supplied it at £72 inc vat.Not to sure were Bosch garadges source there parts. The car was runnig rich at 8% idle and 3% at 3000
Fixed, air mass meter was bugered and making the car run way to rich
Feckin thing not only gut out its got a really lazy start now, gotta give it some revs or else it dies???
10m leads you wont get in the runners thats for sure i just managed to squeeze my 8mm ones in .
