jimmyconway
About jimmyconway
Stoke on Trent
Powder coating & blasting - Stoke on Trent?
jimmyconway replied to jimmyconway's topic in Bodywork and Styling
Thanks. Ive dropped some parts off today & they are very friendly. I didn't know you could have any colour you want. :-d -
Can any Stokies or nearby neighbours recommend where I can get this done? If not I will try Powder Coating Technology Ltd at Lingard St near Hot Lane.
That looks proper. Not sure it's windsor blue cus mine is and it doesn't go so purple. Maybe if i cleaned it.
Car wont start after fitting chip...
jimmyconway replied to jimmyconway's topic in I.C.E, Security an Electrical
I have soldered a socket in & now neither chip works. Whats the print? -
Front suspensions too high # help #
jimmyconway replied to RYSTA's topic in Wheels, Brakes, Suspension and Steering
Ive got Koni's too & know what you mean. The rear looks spot on but the front is too high. I know that Jom do a lowering spring cap which lowers 10-15mm for £20 a pair. If you can get a top mount that lowers like the Bonrath you mentioned combined with the spring cap it might sort it? -
Got some in.pro smoked headlamps for my golf only to find that they are mainbeam only. Anyone know if these are plug & play or will i need to make adjustments to get these to work? They didn't come with bulbs... will i need dual filament bulbs?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=120217074264&ssPageName=STRK:MEWA:IT&ih=002 3hours left.
Only changed the chip' date=' Not ecu. My car is 94 so guess it's obd1. Didn't think that obd2 got any gains from being chipped. -
Not sure, The old one & new one both had a little notch cut out at one end so I assumed they go on the same way. -
I got a chip through a friend. Was originally purchased from ChippedUK. I've fitted the chip myself & now my car wont start. When the ignition is on a buzzing noise sounds. The starter motor turns but it wont fire up. I'm guessing that there might be an issue with the immobiliser. Anyone know where i've gone wrong?
http://www.justmatz.co.uk/products_specials.html
Yes mate i thought that might be the case. Im loving the ride of the koni's but aesthetically it doesn't beat coilovers. Im gonna stick with it for now but i will be back down to terra firma sometime soon.
Looking good Al. How are you finding the drive now you've gone from 17" to 16"? Any better? I'm thinking of going the opposite way now having taken my coilovers off & raised it with -40mm Koni/Eibach setup. I wanna fill my arches with 17's but not if it compromises handling.
Covert 5x98 to 5x100?
jimmyconway replied to jimmyconway's topic in Wheels, Brakes, Suspension and Steering
Thanks mate. Will try them next week.
