porki
About porki
Tunbridge Wells, Kent
Heater Matrix Bypassed, now won't stat
porki replied to porki's topic in Engine Maintenance and Problems
ok mate thanks, i'll check that out tomoro,i hope it's something that simple!! -
92 OBD1 Golf VR6, 140k K&N with relocation pipe to behind headlight 174.4 BHP (137 @ wheels) 177 lb/ft figures are @ the fly, measured at Surrey Rolling Road Problems...Blocked CAT & valve stem oil seals need doing, was running rich too, around 12 on the AFR
yeah, i thought that while i was driving home!! school boy error. it's now running, checked fuel first and was all good, then check for spark. nada. cleaned the contacts on the dizzy and then fired sweet as a nut. but now i've discovered a dripping fuel leak near the rear of the car. oh the joys!! -
that could be a possibility, i'm off home shortly so i'll have a thorough check and report back. The manual does say something about oil pressure and the flashing warning light, but that's about as helpful as it gets! are there any safeguards in the ecu to cut fuelling if it detects no oil pressure? -
don't think so mate - it was idling on it's own then just stopped and won't go again, although i'll go have a thorough check again tomoro - you know what it's like checking the same stuff over and over again! is the flashing oil light normal?? - that's what scared me the most!! -
Hi... I have a '92 golf VR6 on 140k. Couple of nights ago i was driving along and started to get a wet foot, wasn't leaking a huge amount but enough to concern me. Drove about a mile home and parked the car up. Tonight i have gone out to the car, bypassed the heater matrix by removing the two hoses connected to the bulkhead and joining them together. I then filled the water, checked for any leaks while it was cold and then ran it. Idled for about 45 seconds before stopping and now it won't start again at all, it's turning over strongly enough but not firing. The oil light is flashing but the
should be good for me mate
what he said ^^, i'm new to the VR6 thang and would be good to meet some of you guys...
i'm using the H&R cup kit, is very good almost makes the car handle ok! i got mine from motorsportworld.co.uk were about £370 delivered i think...
i think mines windsor blue...
