Days Won
1
c3vrg last won the day on December 1 2017
c3vrg had the most liked content!
About c3vrg
penzance
VR6-SPD87 reacted to a post in a topic: water hose ?
Any ideas where i can get a new Coolant Hose 1H0 121 063 G . Its one that goes (Reservoir > Coolant Thermostat Housing > Auxillary Water Pump ) looked everywhere .
Brilliant thanks for that , For some reason i thought there were 2 on each side , so glad there is only 1 .
VR6CABBS reacted to a post in a topic: couple of questions ?
Thanks its the lower picture ,metal clips , i have some but not sure where they fit , so if anyone has a picture of them fitted please ?
Does anyone know if there are any differnces in carpets fitted to vr6 , gti's highlines etc . Such as the plushness . My vr6 is kinda course . I remember my mk1 scirocco storm and differnt carpet to the gti model .? Also does anyone have pictures of the clips that go on the rear bumper that keep the bumpers closer to the arches , I have purchased some and not sure where the old ones came off . height wise etc ?
Thank you , when you say sliding pins ,do you mean about the bolts that come with a set of pads . Also think they come with loctite on the ends . Is it a good idea to put loctite on the carrier bolts aswell ?
Does anyone have the correct torque settings for my 1995 golf vr6 rear brake carrier and also calipers please . and the front if possible , also should you replace the bolts and sliders on the front and rear when renewing discs and pads ? Best place to get the correct bolts aswell ?
Thanks i may have got one , just out of interest what was yours priced at ?
wanted standard leather steering wheel for mk3 golf vr6 must be in good condition , thanks .
ahh ok thanks, i also tried a differnt wheel and bag , so perhaps its somewhere else. May be there is a control module somewhere in the car.
Mine has the same problem , any idea what the cure was ?
What a stupid thing vw have done , why would they remake the mudflaps without a badge. The ones they had with the white molded beadge was fine . Looks like i will look for some second hand
I just ordered some rear mudflaps for my vr6 however they arrived with tno vw badge on the back , but what is strange there is a recess that looks like a vw badge should fit in . My local vw garage says there is no badge listed for them ? The part number for the mudflaps is 1H6075101 Any ideas ?
can i use a motorised headlight in a non notorised car ? the headlight i bought has a motor in it im not sure if this is ok ?
