scruffy
Everything posted by scruffy
  1. Decided to attack the wheel speed sensor, allan headed holding screw came out no problem but sensor just fell to bits with broken end still in stub axle! is this normal? where is best place to purchase new sensor? JBD
  2. I purchased mine from local Sealey tools dealer, cost about £12
  3. I purchased original aerial from main dealership and in local A1 Motorstore was exact same aerial (no maybe) the shop had both types plain element and wound at £5.99 each! 3 times cheaper than supposed original one, go to good auto store> JBD
  4. thanks will certainly try that, the other rear one was changed by main dealership under warranty as was ABS pump, took them over 2 weeks before they would commit themselves!
  5. My drivers window just stopped working last summer however for some reason it went down about an inch when starting the engine! I do notice now that when I put the ignition key accross into the start position I can hear a clicking noise from inside the door as though the window was on it's way up, I can also hear the passenger one as well, all other windows work no problem, would this indicate anything obvious? there is no clicking sound when the switch is pressed like there is on other front window? thanks for now JBD !sad
  6. Hello everyone, since my last posting I purchased a code reader best thing ever! I am getting rear passenger sensor code faulty, is it possible it may be the ring? and if so what is involved getting at the ring? and can anyone tell me what size of allen headed socket is needed to undo the sensor? thanks for now! JBD !sad
  7. Does anyone know where I can obtain the tool (do I really need one) to remove the leads from the spark plugs, I just discovered that this tool should have come with the car. thanks J B D.
  8. Thanks everyone for reply, I put the car in lock-up on the Friday started it up on the Monday morning and the ABS light came on! I put it into garage to have complete overhaul of rear brakes 2 weeks ago new drilled discs and green stuff pads etc, mechanic said there was nothing wrong with ABS ring or sensor (ie Nor dirt or stones)although he never removed the sensor so I guess it's the sensor, just priced one from GSF
  9. My ABS light has come on and shows fault with wheel speed sensor, ie; Rear left wheel speed sensor G46 faulty, can anything be done with these sensors? or is it best to just renew them?. Thank you. J B D !lol
  10. Several weeks ago after leaving car in lock-up for 4 days (Arthritis problems) the dreaded ABS came on, I have not used car untill today, when it was taken to mechanic to have complete rebuild of rear brakes (same as front) on collecting car he told me he lost thesmall rubber cap from top of brake fluid reseviour which holds plastic rod from rising? however he used another plastic cap which seems ok, fluid level is OK, as is hand brake warning light switch, nothing has been touched except new discs, bearings, and pads, abs rings changed over (they are only 18months old) I read in Bently manual
  11. the abs light has come on again after leaving car standing in garage over weekend! I have had just over 1 years use out of car since main dealer put new abs pump on and 1 rear wheel sensor under warranty, if I check wheel sensors and find say broken wire or whatever will abs light go out or do I need trip to main dealer to reset light? there is no difference whatsoever with my brakes since light came on, car is 1997 70oddK is there a logical approach to my problem( other than get rid of it) thanks guys Jim. !sad
  12. can anyone tell me what is involved in fitting a tow bar to the vr6? thank you. jbd
  13. I have noticed on pictures small like mini KN filters positioned up near throttle body, is this a good way to go, is it an improvement etc;? if so where does it go and what type does one get, I asked at local autoshop who sell them, but chap there looked up book and said they don't fit VR6s, thanks. !sad
  14. I have noticed a slight movement in engine especially high gears! is this the same mount that will be giving me the movement?
  15. Just came back in after about 12mls of mostly above 100mph and oil temp never goes above 96 dropping to 92/94 on the last 2/3mls behind the SLOTHS
  16. I have the complete workshop manual (wiring diagrams etc) for VR6, if I can help let me know, my drivers window has died also and VW garage wont look at it.
  17. Thanks for email, I have just phoned for price of SUBURU WRX and going for drive, I really like the vr6 but cant live with things that don't work it wrecks me mentally to know somthing is knackered, I think I need some knid of therapy but maybe at 55 I'm to late. WRX HMMM!
  18. Just thought I would pass on report from VW garage this morning attempting to fix drivers window, they say it is far to involving and is now a specialised job, they gave a customer bill of
  19. anyone know about windows? my drivers side has stopped, the passenger side also stopped, took switch apart used switch cleaner and it works but not drivers side! also notice that when attempting to close or open windows with key in front door locks all windows work axcept drivers side and sunroof which should close with windows stays open, is there a fuse or maybe the switch is buggered!
  20. angle grinder tool will probably do the job? but make life easy! sealey sell tool for
  21. I changed mine to Zimmerman with Pagid, great result, car has done 70k, no problems. Moto of local maindealership, (I couldn't fix your Brakes so I make your Horn louder).
  22. Thanks for reply and info, I was worried about disturbing abs ring that has to come off old disc and go onto new one, main dealership reckons 3hrs work at
  23. would like to know what problems I might encounter changing rear discs, have heard that after changing abs rotors/sensor there can be problems due to abs rotor not being aligned up and it switches off abs? I am thinking about drilled and grooved, with green stuff,any ideas or suppliers, JBD
