bear
Everything posted by bear
does anyone know were i can find the clutch positioner vacum valve, only had the car two days and the engine light has come on, think its something todo with cruise control
after 7 years with the hand brake warning light on iv`e finally fixed it, had to put a new hand brake cable on for the mot, had my son helping in the car whlie i was working under the car, he took the hand brake off the car and noticed the wire`s were bare touching the cars bodywork, a bit of soldering and no red light, just had to make sure the wire`s go over and not under the handbrake to the switch.
Less than a week to find mine,parked in the pub car park in Anstey, then saw it in auto trader for sale, had the AA check it out had some faults so brought it !.Had it 8 years now and it never breaks down. 246000 miles so far,did the gearbox bearings last year a bit worn out nice and quiet now. best car i`ve owned.
Knocking In Nearside Front Area.
bear replied to vr6_super's topic in Wheels, Brakes, Suspension and Steering
repiaced the cv joint, nice and quiet now, was`nt a lot of grease in the joint plus a bit of water no wonder it was knocking, only took 2 hours -
sounds like the outer constant velocity joint ,iv`e got the same problem, fitting a new one later, dont think it`s the strut tops -
sorted the hand brake,fitted a new cable, good has new now. the old cable had a few splits in it which wont help.
had a look under the car to check , looked ok, might strip it down tomorrow, but the brakes work fine,
i took the nuts of completely conected the cable to the caliper but then the cable was to short to fix back, thought about fitting a new cable but might be shorter because its new
fitted a new brake caliper, put the old pads back in but now the handbrake cable is to short, anybody have any good ideas to fix it
just finished fitting a new heater matrix, the only thing that don't work is the fan, think i put all the wire's back,still a bit damp near the fan ,hoping it's a fuse gone
I fitted new top mounts last june and the mot man said they need replacing again !i used gsf mounts but have ordered new pair fron vw main dealer, oniy £25.i have Eibach coilovers fitted which i think are the same as FK,just wondering if i've fitted them right, but you can't really go wrong !
youv'e put me of doing my wishbones,the rear bushes are worn,not sure what to replace them with,poly or original.all the bolts will come of but not tryed the 3 13mm.thinking of buying new wishbones and getting the bushes pressed in,then all i've got to do is take the old ones of and fit the new ones,sounds easy,bit like when i changed the rear wheel bearings !
is that to low !what were you looking for ?
hows £30 sound including p&p
looking for a roof aerial,snapped of ! main dealer wants £70 not paying that !can anybody recommend anywere
i have the same problem,had the drivers seat out to check the wire from the handbrake to the fuse box,looked ok,auto electrician said it might be behind the dash,£120 to fix.or if i take the dash out £40
ordered all new parts, some think is bound to break,should be easy, tryed the 3 allan key bolts,they are all ok,shouldn't have said that probaly spend all day on it !
iv'e got the same problem,if i undo the 3 allen key bolts,will the whole lot come of including the transfer pipe,was thinking of taking the bumper of because the 2 allen key bolts between the housing and transfer pipe have rounded of,
only took half hour to do the job,looks a lot better with the head rests in,suprised how easy it was .
Will have to strip down the old seats to get the parts i need,would have thought leather seats have rear head rests as standard
just brought some colour concept leather seats,the trouble is theres no holes for the rear head rests,going to cost £60 to cover head rests in leather but cant give me a full price to fit them in because i dont know if theres any tubes in the rear seats,does anybody know if the seats have the tubes for head rests under the leather?
what coilovers are you using now,iv'e got the spax psx kit fitted at the minute,but will be changing to the rsx soon,the coilovers on ebay look too cheap
