Ciaran 4 Posted July 21, 2006 Report Share Posted July 21, 2006 i have just had now pads and disks fitted at the rear for my MOT ever since the hanbrake light is on all the time and the cable sems rather slack.im guessing their is some sort of low pad warning on th car to tell me when he pads are getting low is it possible it's damaged or is it something else?? il be going back to the garage on monday but jsut want to make sure the care is safe??oh and thei brake fluid level is fine Link to post Share on other sites
Earwig 89 Posted July 21, 2006 Report Share Posted July 21, 2006 Just sounds like they did not tighten up the cabel properly.While it is slack don't rely on it to keep the car still. Put it in gear when you park up and leave it.Mark. Link to post Share on other sites
Ciaran 4 Posted July 22, 2006 Author Report Share Posted July 22, 2006 i always do that anyway mate will get them to tighten it on monday unless it's easy enough for me to do it myself??? Link to post Share on other sites
Ciaran 4 Posted July 24, 2006 Author Report Share Posted July 24, 2006 well tightened the cable today and the light is still on when the handbrake is off fluid is filled up to the top and sensor connection is clean and no broken wires.brakes work fine amy ideas?? Link to post Share on other sites
dubloke 4 Posted July 24, 2006 Report Share Posted July 24, 2006 try another sensor, they do fail sometimes! Link to post Share on other sites
spindat45 0 Posted July 25, 2006 Report Share Posted July 25, 2006 Check the handbrake switch Ciaran. It may have been damaged or come off when the handbrake cables were unadjusted. From memory the switch is located under the handbrake lever where it clips on and is pressed when the handbrake is released. If you find it then you should be able to open and close it with your fingers and check whether the light goes on and off. You may need to un-adjust the handbrake cables first and remove the handbrake lever from its mountings. (Not as difficult as is sounds btw)Kevin Link to post Share on other sites
Ciaran 4 Posted July 26, 2006 Author Report Share Posted July 26, 2006 well i tried the switch when i tightened the cable it seems smooth enough and the connection seemed fine but il take it out and check the resistance across the switch in the open and close position and if it's not this then it's the sensor on the brake fluid resevoir.just seems a coincidence that it only came on after i had new rear disks and pads fitted or it could be coincidence!! Link to post Share on other sites
spindat45 0 Posted July 27, 2006 Report Share Posted July 27, 2006 Just a though mate. Check the connector on the reservoir plug for any breaks and also that it plugged in properly. Its gotta be to do with something that as touched when the work was being carried out. Otherwise you could be entering the "VR6 Twilight Zone" Link to post Share on other sites
