hi there. i've had my vr6 for a little over a year now and although it looks good in standard form i am growing tired of its suspension that seems to be made with treacle. what i wanted to know was the best wheel, tyre and suspension compromise. i would like the car to be reasonably low but i don't want to roll the arches if poss. i was thinking maybe santa monicas or rs6 replicas in 7j 17 form and a 40 mm lowering. any thoughts. cheers
what suspension kit do you suggest. from scanning the posts on here i think the g-max kit is the best. am not looking for coilovers, unfortunately money IS an object. just a 40mm drop. from what the folks on here say a 35mm kit eill do this?! cheers guys.
im on koni sport suspension kit( 25-30mm drop),it is plenty low enough for every day use.after few hundred miles it settle to about 35mm all round :) when you change to new suspension don't forget to renew the bump stops,top mounts & berings and the tracking check/reset.
