jonnyedinburgh 0 Posted February 17, 2006 Report Share Posted February 17, 2006 I've found when fitting coolant hoses that they can be a bugger to get over flanges. Is there anything I can use to lube the hose or flange or is there some special technique I should try? thanks Link to post Share on other sites
craggsy 91 Posted February 17, 2006 Report Share Posted February 17, 2006 I wiggled mine alot to get em over the lip, went on fine for me like that Link to post Share on other sites
dellert 0 Posted February 17, 2006 Report Share Posted February 17, 2006 try some fairy liquid, very good lubricant!!!! or just plain water or antifreeze..... Link to post Share on other sites
stockers 1 Posted February 17, 2006 Report Share Posted February 17, 2006 i would say water, you don't want them slipping off, which could happen if you used something like fairy liquid. Link to post Share on other sites
57ORM 0 Posted February 17, 2006 Report Share Posted February 17, 2006 I found the best way was to get a cup of hot water and dip the hose in it prior to slipping it over the flange the heat gives it a bit more flex and they just slide over Link to post Share on other sites
Justicevr6 0 Posted February 18, 2006 Report Share Posted February 18, 2006 When I was serving as a plumbers mate I was told that fairy liquid is no good for rubber as it rots it. Link to post Share on other sites
jb9999 0 Posted February 20, 2006 Report Share Posted February 20, 2006 I use swarfega without the grit in it or a bit copperslip on the flange, but fairy is as good as anything. Link to post Share on other sites
jon@vagworx 0 Posted February 22, 2006 Report Share Posted February 22, 2006 As 57ORM said, use boiling water, this will expand the rubber and will nearly fall on Link to post Share on other sites
antera309 3 Posted February 23, 2006 Report Share Posted February 23, 2006 Cleaning all the crud off the flanges helps when it comes to getting the hoses on, and reduces the chances of leaks later on. Link to post Share on other sites
dubloke 4 Posted February 23, 2006 Report Share Posted February 23, 2006 nice big bucket of very hot water and a little car wash, chuck them all in and leave while you remove standard ones, then hey presto, they fit themselves. Link to post Share on other sites
