feltch racing 0 Posted December 20, 2005 Report Share Posted December 20, 2005 help, my main fan never comes on when im in traffic the temp goes to about 110 degrees, checked the fuse an its ok ??? Link to post Share on other sites
matth76 1 Posted December 20, 2005 Report Share Posted December 20, 2005 Could be the thermostat that links to the fan. Best bet is to ring a VR specialist who will give very good advice over the phone and if they're local get to look over your car (much better and far cheaper than a main dealer) - needs to get sorted mate as temps in the vr engine bay can soar. If you're in the south try Storm Developments or The Phirm. If you're in the midlands best place is Stealth Racing. Quite a few others around though that are excellent. Link to post Share on other sites
feltch racing 0 Posted December 21, 2005 Author Report Share Posted December 21, 2005 tryed the fuse and the main wire but the fan stil aint cumin on Link to post Share on other sites
VR6Pete 1,455 Posted December 21, 2005 Report Share Posted December 21, 2005 could be fan thermo switch? Link to post Share on other sites
richievr 1 Posted December 22, 2005 Report Share Posted December 22, 2005 my suggestion would be to connect a wire direct from the battry to the power terminals on the fan motor..if it spins then you know the fan is working and your problem is something as above - the switch or the thermostat... Link to post Share on other sites
mk3anni 0 Posted January 2, 2006 Report Share Posted January 2, 2006 or unplug the thermo switch and bridge the wires, if the fan spins then the thermostat has gone Link to post Share on other sites
