illiance 0 Posted December 13, 2005 Report Share Posted December 13, 2005 now that my starting problems are sorted (new battery was all it needed ) I need to sort the radiator out. I was quoted Link to post Share on other sites
ingham 5 Posted December 13, 2005 Report Share Posted December 13, 2005 try radiator services type place had one fitted for less the i could get one form parts trade counter Link to post Share on other sites
28v6r 0 Posted December 13, 2005 Report Share Posted December 13, 2005 Lets pray that you've got thin or smallish hands.. Tubby large "shovels" just won't crack it... there ain't a lot of room to play in there.. and be very careful when refitting the radiator not to damage the fins ir tubing as its very tight and barely clears the inlet manifold... Link to post Share on other sites
mk3anni 0 Posted December 13, 2005 Report Share Posted December 13, 2005 Lets pray that you've got thin or smallish hands.. Tubby large "shovels" just won't crack it... there ain't a lot of room to play in there.. and be very careful when refitting the radiator not to damage the fins ir tubing as its very tight and barely clears the inlet manifold...Don't you replace it from the front???? Link to post Share on other sites
illiance 0 Posted December 13, 2005 Author Report Share Posted December 13, 2005 ingham, did you have yours done at a local or national radiator place? Link to post Share on other sites
jayvwvr6 0 Posted December 13, 2005 Report Share Posted December 13, 2005 ive done mine,its a long job but easy to do,yes the whole front gotta come of head lights,front cross member,bumper and if you got aircon like me you can not replace the rad without disconecting the aircon,its a pain but just take your time and you should be ok. Link to post Share on other sites
28v6r 0 Posted December 13, 2005 Report Share Posted December 13, 2005 Incidentally, mines a 1994 Passat hence how mine came out the top side of the engine bay and as jay says .. "you just gotta take your time..." Link to post Share on other sites
antera309 3 Posted December 14, 2005 Report Share Posted December 14, 2005 Replacing the rad will be much easier if you take the front of the car off. This is not as difficult as it sounds and it beats slicing up your hands! Link to post Share on other sites
craggsy 91 Posted December 14, 2005 Report Share Posted December 14, 2005 So easy from front of car...couple of hours tops to change and fill it up Link to post Share on other sites
drewvr6 0 Posted December 16, 2005 Report Share Posted December 16, 2005 ive done it twice from the front ,remove headlights,but you do not need to totally remove bumper and crossmember ,unbolt the bumper and slide it forward, this will allow you to access crossmember bolts slacken these to allow it to slide forward about an inch and that gives you the clearance to remove, refit new rad. Link to post Share on other sites
illiance 0 Posted December 18, 2005 Author Report Share Posted December 18, 2005 once you have got to it, how easy is it to actually remove and replace the radiator, is there anything I need to watch out for? Link to post Share on other sites
drewvr6 0 Posted December 19, 2005 Report Share Posted December 19, 2005 no its straight forward only the bottom hose can be akward to remove from the top of the engine bay,so if you cant get it you will have to jack the car up for this part of the job Link to post Share on other sites
