stockers 1 Posted November 24, 2005 Report Share Posted November 24, 2005 hi all, well.... after having a little mayo on the oil filler cap and needing to top th oil up a bit, i just checked the coolant reservoir and the new coolant has turned into thick oily sludge! not just a bit of discolouring and a bit of a film but thick sludge from top to bottom.i was told by the garage the head gasket had been checked and passed!!!!!!!! !mistrust could be the oil cooler? Link to post Share on other sites
Nerih 0 Posted November 24, 2005 Report Share Posted November 24, 2005 its obvious something is contaminating the water supply, replace the coolant and see what happens, driving your car with sluldge as coolant, isnt a good idea, locate the source of your leakage of oil and seal it up, i would go to another garage and check the headgasket, just for second opinion, your condition is serious m8.....try not to drive her. Link to post Share on other sites
six appeal 53 Posted November 24, 2005 Report Share Posted November 24, 2005 Oil coolers are a weak point too and prone to failure, particularly if the waters not changed regularly and the correct Anti Freeze not used. Hope its just that mate and not your Head gasket.Simon. Link to post Share on other sites
stockers 1 Posted November 24, 2005 Author Report Share Posted November 24, 2005 cheers nerih, on the plus side the car is still under warranty so it isn't going to cost me anything to get it fixed. bit of luck i checked the coolant really, i was fitting some bonnet lifters and thought i'd have a little look round the engine to see if anything needed topping up! !dodge Link to post Share on other sites
Nerih 0 Posted November 24, 2005 Report Share Posted November 24, 2005 yeah like you and sixappeal said, check the oil cooler too. Link to post Share on other sites
