Guest carlos1969 Posted November 23, 2003 Report Share Posted November 23, 2003 hi allI have a intermittent fault on the idle stabilization code no. 00533, on a 1996 vr6, ant ideas on how to resolve this prob. ?!chreers 8) Link to post Share on other sites
jcorallo 0 Posted December 8, 2003 Report Share Posted December 8, 2003 Idle Regulation Adaptation....1) use VAG-COM to perform output tests on it - you'll be able to hear it opening and closing during the test.2) check the wiring to it3) clean it - might be gummed up inside not allowing it to operate to its full throw.4) replace... Link to post Share on other sites
VR6Pete 1,455 Posted December 8, 2003 Report Share Posted December 8, 2003 does anyone have a list of all the error codes from VAG-COM ? wud be real handy for everyone to have access to all the codes Link to post Share on other sites
jcorallo 0 Posted December 8, 2003 Report Share Posted December 8, 2003 you can just do a search on Google actually and that can find the translations - you usually come across sites like www.onboarddiagnostics.co.uk which has some info...Jules Link to post Share on other sites
ninja 0 Posted December 9, 2003 Report Share Posted December 9, 2003 The Bentley manual I have lists them all at the back. If anyone knows how to post them I'll scan them and email them assuming there's no copyright issues. Link to post Share on other sites
Guest carlos1969 Posted December 9, 2003 Report Share Posted December 9, 2003 hi all thanks for info.Did the breather filter mod. ie removing the pipe between the rocker cover and throttle body, removed and cleaned the throttle body and rechecked on vag-com and no faults found Link to post Share on other sites
VR6Pete 1,455 Posted December 10, 2003 Report Share Posted December 10, 2003 be cool if sum1 can write up a guide for that! Link to post Share on other sites
binliner 0 Posted December 10, 2003 Report Share Posted December 10, 2003 If we do a guide for something do you just want pics and text emailed and you do the rest? Link to post Share on other sites
