KW are really good i have them on my GTI. I have the V1 which i think are enough. The V3 are completely adjustable, so not only can you set the height you can also adjust dampening and rebound hence the high price tag. If you want coilovers just to have a variable ride height and want KW then just get the V1. If you want dampening adjustment then get the V2. Unless you do track often and need all the adjustment possibilities of the V3's, i would leave them alone.
Or as Justin says go for the FK ones as they are identicle to KW as they both use Koni inserts (dampers)! ;) But from what i know and have been told by people here in Germany KW are better quality than FK as the KW are all stainless steel so less prone to rusting. Where as the FK ones will rust in months unless you also get the stainless ones from FK (the Silverline ones which are available in both Konigsport and Highsport). :)
