firstly does your air con work? it might even with that hole in!! it looks like the main veins are still intact and its just cooling fin damage, otherwise all the air con gas would of escaped, the condensor is only for your air con charge to circulate through like a rad, mine has a stone hole much smaller than that and it sprayed illuminous green shite everywhere!!! so you could be on a winner, gsf do them way cheaper than vw if you do need a new one, you can tell if the aircon pump is still kicking in when you operate it it should clunk into place!
