p1vsg 0 Posted September 14, 2005 Report Share Posted September 14, 2005 does anyone know if it's possible 2 colour code the door trims because due to the texture some say that it's not possible to do. i know there is the option of fitting cl items but the problem is finding them at a reasonable price.I'd be very greatful for any info as i'll be undertaking this on my own.thanx Link to post Share on other sites
dubloke 4 Posted September 14, 2005 Report Share Posted September 14, 2005 if you use varying grades of wet and dry, or,if you're carefull, a detail sander, you can de-texture the strips yourself! then using plastic primer you can get a smooth surface to put your top coat colour on! tkae your time and it will have the desired effect! Link to post Share on other sites
p1vsg 0 Posted September 14, 2005 Author Report Share Posted September 14, 2005 would you know what grade wet and dry to use?another tip i've been given is to use plastic primer filler and that would give the desired effect then paint and lacqure.lets just say id like a second opinion of this Link to post Share on other sites
dubloke 4 Posted September 14, 2005 Report Share Posted September 14, 2005 you start with coarse wet and dry and work down to fine, so a combined pack would be sufficient. start with summat like 80 to remove the grain then work down to 2400. use lots of water too! plastic filler primer is fine to use once you've smoothed it down, but to spray it directly onto the textured surface would require so much paint, that you'll have probs with drying and it will prob sink anyway and look poo! rubbing it down, though time consuming, is the best option imo! Link to post Share on other sites
p1vsg 0 Posted September 14, 2005 Author Report Share Posted September 14, 2005 would 2400 grade wet and dry be ok for goin over the laquer before a final polish?cheers 4 all your help much appreciated.oh and your engine bay looks heavy!! saw it in the flesh at E38 and WOW! Link to post Share on other sites
