Palkid7 0 Posted August 4, 2005 Report Share Posted August 4, 2005 hi, I have a 93 VR6, it has been misfiring for a while, well it comes and goes, but latley I have noticed that it happens alot and the misifinr occurs more, causing the rpm to dance and sometimes the engine to die when it is very humid, I took the car to a mechanic, he gave a list of stuf to buy, fuel filter, fuel pump, but nothing !! I checked the site and thought that it might be the plugs and leads, so I changed them, but what happened now is that with the new plugs, the car started to be shaking more than before yet it goes away when I step on the gas !! plz help me out here !! I am in a miss and I need to get my car fixed asap !!! !amazed Link to post Share on other sites
purple highline monster 0 Posted August 4, 2005 Report Share Posted August 4, 2005 it does sound electrical, what year is your car? could be coil pack breaking down if it has one? there is a guide on how to test it on here. double check you have the right plugs and leads and all are fitted correctly Link to post Share on other sites
ingham 5 Posted August 4, 2005 Report Share Posted August 4, 2005 have a look at the coilpack in dark you will see if thats it Link to post Share on other sites
Palkid7 0 Posted August 5, 2005 Author Report Share Posted August 5, 2005 what should I look for at the coilpack ?!? Link to post Share on other sites
ingham 5 Posted August 5, 2005 Report Share Posted August 5, 2005 follow igntion leads to where they all meet and look for blue sparkes(try reving engine a bit) .if you can see them its your coilpack Link to post Share on other sites
Palkid7 0 Posted August 5, 2005 Author Report Share Posted August 5, 2005 Guess what guys! I found the problem and fixed it !! I checked the coilpack and there was a plastic cover inside it that was loose !! I used some plastic tape and wax to fix it, and the magic worked !! the car is even better than when I bought it !! I guess the mechanics I deal with are loosers !! Thank u guys for ur help !! and I realy respect u all !!The one and only PALKID7 ! Link to post Share on other sites
Palkid7 0 Posted August 5, 2005 Author Report Share Posted August 5, 2005 by the way there was no sparkels when I checked ! Link to post Share on other sites
bazz780 0 Posted August 6, 2005 Report Share Posted August 6, 2005 did you open the coilpack? Link to post Share on other sites
Palkid7 0 Posted August 8, 2005 Author Report Share Posted August 8, 2005 Yes I did ! Link to post Share on other sites
