Daverse
Mk3 Syncro / 4Mo conversion setup
Hello,
I am selling my setup to convert a mk3 platform to the 4motion drivetrain from a mk4.
included is:
02M gearbox with shifter tower and transfer box
02M propshafts, these have been powdercoated gloss black and look lovely, however the painter has sprayed straight over the bolts and will just require cleaning out.
Mk4 rear cradle
Rear Haldex diff
diff bracket that runs across the prop
4motion rear driveshafts
Mk3 syncro rear axle
rear wishbones, hubs and carrier
mk3 axle plates
Rear driveshafts to mix and match with how you want the setup ( I was going to cut and reweld the mk3/4 shafts together)
ARB (a bit tatty but is solid)
Also got a bag of brand new bolts to rebuild the rear axle.
£700 for everything, open to offers
collection from LN10 only
Pics:
76607545_483680275571430_1828308994553282560_n.jpg76609913_988025494890436_1032100380898492416_n.jpg76762566_494229344508402_8068808183998578688_n.jpg77098045_963959313976340_1902669833523167232_n.jpg
I believe so, you would also have to cut the spare wheel well out. I was going to fab these myself. Also if you are running turbo probably a bit out the bulk head too
