Hello, I’ve had my mk3 12v for a while now but only just got round to doing the necessary work it needs. The stage I am at is the head is at the machine shop being skimmed and ported. The cams were not timed correctly when I bought the car so therefore I will have to time the engine when I get the head back. Which after some research I believe can be done without removing anything other than the cams????? My thoughts are while the coolant is drained out and I don’t know what coolant was in the car when I bought it. It needs replacing. Do i need to flush the system??? And what coolant should I use???  Btw this is my first project so forgive me if I am not making that much sense
