Vento Challenge VR6 Race Car
Vento Challenge VR6 Race Car £7000
Located near Thatcham, Berkshire.
Race ready car set-up to race in the VAG Trophy Championship. Also suitable for the classic VW Cup and numerous national championships.
  • ·         2005 3rd in VW Cup Championship
  • ·         2006 2nd in VW Cup Championship
  • ·         2015 3rd in VAG Trophy Championship (Class B)
  • ·         2016 2nd in VAG Trophy Championship (Class B)
Build Spec:
  • ·         2.8 VR6 BDE 24 valve Engine with Shrick Camshafts giving 224BHP at the flywheel measured on Shark Motorsport rolling road.
  • ·         5 speed 02A Gearbox with brand new unused gripper plate diff and original close ratio Gemini gearset. Rebuilt gearbox just fitted including new VW release bearing with zero miles after fitting.
  • ·         Larger than standard drive flanges which have thicker and stronger 8mm bolts fitted. These do not come loose like the thinner standard ones.
  • ·         Brand new Helix Clutch and Pressure plate fitted with zero miles.
  • ·         Quickshift gear lever.
  • ·         KMS ECU with mini dash. Programmed by Storm Developments.
  • ·         KW Coilover rose jointed suspension with adjustable ride height, Bump and Rebound adjustments. These were serviced over winter break by KW and all 4 units had new piston rods fitted.
  • ·         AP CP3580 4 pot front calipers fitted with new front and new rear pads in Mar 2017.
  • ·         8 x 17 inch wheels:
o   4 fitted with Dunlop Direzza DZ03 225x17” tyres fitted April 2017 and have been used for 4 races.
o   4 fitted with used Clio Cup Dunlop wets.
  • ·         New VW clutch slave cylinder fitted Sept 2016.
  • ·         FEV 3.5L electrically operated fire extinguisher serviced Mar 2016.
  • ·         Recently re-sprayed shell (white).
  • ·         Front wishbones rose jointed.
  • ·         Rear axle with Proflex poly bushes and rear anti-roll bar.
  • ·         New TR-S black seat.
  • ·         Seat belts 1 season old.
  • ·         Silencer repacked with Acousta-Fil May 2017
  • ·         Spares new and used include:
o   Doors, bonnets, boot lid, rear axle, bumpers front and back.
o   Helix racing clutch plate + pressure plate.
o   Steering rack.
o   Water pump, power steering pump.
o   Long and short bare drive shafts. New spare GKN inner and outer CV joints. Kept as separate parts to make up whichever drive shaft should one fail.
o   Cylinder head.
Call Barrie 01189710106 or Martyn 07899882554
Edited by barrie culley
Remove Trailer
  • 3 months later...
  • 4 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
