Sign in to follow this
carsonbutters
02m Swap info
Mines booked in at the Phirm for this next year.
gearbox mount needs to be cut from the subframe and moved back 1/2 inch to clear drive shafts, good pics here  but only first couple of pages relevant - https://www.diyauto.com/manufacturers/volkswagen/generations/corrado/diys/consolidation-of-information-haldex-into-corrado-02m-syncro-by-jamess-1
custom gearbox mount - https://www.epytec.de/de/motor-getriebe-halter/vw-weitere/6221/6-gang-getriebehalter-02m-fuer-golf-passat-corrado-g60-16v-vr6-getriebe-halter-dxw-dqb?c=41
custom driveshafts
possibly a polo gear shift box
24v thermostat housing
24v starter motor
clutch and flywheel
oh and a good gearbox,  HotGolf from the GTi forum is rebuilding a DRP (alleged strongest 02m) box for me and also going to remove some of the issues with the 02m.
which are -
hollow input shaft which can flex causing gears not to mesh - fix is weld shaft inside to create solid shaft
weak selector forks - VW upgraded them, so get latest revision or at least remove the rivet and weld a bolt instead.
plastic sliders wear out  - upgrade to bronze
4th gear shaft moves - 4th gear support, stops issues with gears not meshing under high torque
case splitting - custom supports
most of this is available online, Darkside do most of them and gives a small explanation why. top 6 items here (http://www.darksidedevelopments.co.uk/gearbox-parts/) i am in no way affiliated with the site ;-)
good luck
s
