shail 0 Posted June 22, 2005 Report Share Posted June 22, 2005 Anyone used / seen 99RON super unleaded at Tesco? Apparently cheaper than Shell Optimax at 98RON. As Tesco say ...."every little helps" Link to post Share on other sites
stu h 0 Posted June 22, 2005 Report Share Posted June 22, 2005 hadn't noticed they were noing it. what sort of price is it compared to regular unleaded?saw that sainsburys were doing super the other day. think I'll stick with optimax tho Link to post Share on other sites
ingham 5 Posted June 22, 2005 Report Share Posted June 22, 2005 will have to try 99ron Link to post Share on other sites
hvr6 88 Posted June 22, 2005 Report Share Posted June 22, 2005 They have it at Tesco in Cheshunt - Brookfield Centre.... 90.9/litre ... however will prolly stick with Optimax Link to post Share on other sites
Col_M 0 Posted June 22, 2005 Report Share Posted June 22, 2005 Is the Tescos 99ron still only available in a few stores nationwide? last time i checked these were the places it was available,99 OCTANE STORES:Beford 1,Cheshunt Extra,Crawley Hazelwick,Gallions Reach Extra,Gillingham Kent,Lakeside Extra,Ramsgate Manston,Salisbury 2,Sandhurst Extra,Sevenoaks Riverhead,Stevenage Extra,Winchester.Does it have the cleaning additives that Optimax and Ultimate have? that is the only reason i use them. I doubt i'd see much of a difference going from a 95ron to a high octane fuel such as Tescos 99ron because i'm running a standard VR6. I've always been under the impression that unless you have a high compression ratio or a forced induction engine there isn't much need for high octane fuel, you're not likely to have pinking issues with a standard engine using 95ron, the ron number after all is only the fuel's resistance to detonating due to pressure/heat.So unless the Tescos 99ron fuel has cleaning additives i don't think i'll be getting any Link to post Share on other sites
