B4VR6 193 Posted September 21, 2015 Report Share Posted September 21, 2015 (edited) I seem to have a hesitation problem at low rpm. If on idle I press the throttle to rev the revs drops slightly (hesitating) below 800rpm then revs. Also while cruising at 30 mph while the revs are low it's jolting the car like its misfiring. I have a cone filter with a cold air feed to it. Now I also think it could be the maf sensor. Now the maf sensor and throttle position sensor are fair new. The crank sensor hasn't been changed. Oh and I have a catch can with a little breather filter instead of the pcv. A little advice would be great help Edited September 21, 2015 by B4VR6 Link to post Share on other sites
noggin 29 Posted September 21, 2015 Report Share Posted September 21, 2015 Mine was doing something similar last week and it turned out to be the HT leads. I was still running the original leads, car has 60k on the clock! Link to post Share on other sites
B4VR6 193 Posted September 21, 2015 Author Report Share Posted September 21, 2015 Cheers might be worth getting mine scanned then. Link to post Share on other sites
