Zonda_ 0 Posted June 11, 2005 Report Share Posted June 11, 2005 Since having my tracking and camber setup my wheel is now off centre, not a huge amount but ehough to piss me off! How do I go about straightening it bearing in mind it has an airbag? Link to post Share on other sites
MrBen 0 Posted June 11, 2005 Report Share Posted June 11, 2005 Disconnect battery, remove airbag (two allen bolts on the back of the steering wheel), unplug airbag (the plug pulls out, but is usually pretty stiff), then it's normal unbolt the wheel. As per good old Mr Haynes, replacement is the reverse of removal... Link to post Share on other sites
Zonda_ 0 Posted June 11, 2005 Author Report Share Posted June 11, 2005 Cool, cheers! Link to post Share on other sites
MANIA 0 Posted October 20, 2006 Report Share Posted October 20, 2006 I've just had my wheel alignment done and the same thing has happened.Is the steering wheel nut easy to get to with a spanner or a big socket (how big is it?), or is it a hammer-and-screwdriver job to bash it loose? Link to post Share on other sites
mk3anni 0 Posted October 20, 2006 Report Share Posted October 20, 2006 Socket on a short extention is fine.Dunno how big....big enough! Link to post Share on other sites
Petesvw 0 Posted October 20, 2006 Report Share Posted October 20, 2006 Mk2's are 24mm, don't think a mk3 will be far off! Link to post Share on other sites
