No mate its a piece of piss. Remove the grille and there's 3 10mm bolts on top of the bumper and 4 on the underside where your number plate is. Remove the bumper obviously unclip the front fogs and indicators. Undo the bonnet release cable and under the slam panel there's a round multi plug for your lights ect twist that to get apart. Unclip the plugs from the fans remove the top and bottom rad pipes. I split the air con pipe from slam panel next to the passenger headlight. Next undo the 2 bolts at the front of wings either side then undo the 4 13mm bolts where the crash bar is bolted to the chassis legs then the front panel should just pull off
