Golfman 0 Posted June 5, 2005 Report Share Posted June 5, 2005 Does anyone know how to or know someone that can remove the drivers airbag? because i need a new steering wheel. Cheers. Golfman Link to post Share on other sites
acf8181 0 Posted June 5, 2005 Report Share Posted June 5, 2005 -disconnect battery-leave for 15mins to decharge-undo two allen bolts on back of wheel-remove bag carefully, do not drop, and store upright-undo centre bolt and remove wheel Link to post Share on other sites
binliner 0 Posted June 5, 2005 Report Share Posted June 5, 2005 or just do the above minus the irst 2 stages Link to post Share on other sites
MrBen 0 Posted June 5, 2005 Report Share Posted June 5, 2005 Disconnecting the battery I would consider essential, but there is no need for a 15 minute wait. Link to post Share on other sites
binliner 0 Posted June 5, 2005 Report Share Posted June 5, 2005 I've never disconnected the battery neither has the VW specialist place I go to but then again it doesnt hurt either! Link to post Share on other sites
MrBen 0 Posted June 5, 2005 Report Share Posted June 5, 2005 Intriguing, I've always trusted the Bentley manual for this sort of thing, and that says you should disconnect. I'd be a bit wary plugging it back in with the battery connected as if some how a spark set it off, that would bloody hurt!! Link to post Share on other sites
Matt W 4 Posted June 5, 2005 Report Share Posted June 5, 2005 I've never disconnected the battery neither has the VW specialist place I go to but then again it doesnt hurt either!Yeah i bet it doesn't hurt when it goes off accidently while your handling it! :@ When i took my steering wheel off i disconnected the battery and waited for 15mins to be safe and i had no problems. Remember the airbag is a small explosive device so mess with it at your own risk!Also by disconnecting the battery there is less chance of you getting a airbag warning light upon refitting! Link to post Share on other sites
acf8181 0 Posted June 6, 2005 Report Share Posted June 6, 2005 yeah, the first too steps are probably not essential...but i'd rather be cautious when it comes to explosive devices. Link to post Share on other sites
Golfman 0 Posted June 6, 2005 Author Report Share Posted June 6, 2005 Cheers guys. I will be crapping it waiting for it to explode in my face. I will have a heart attack. Cheers Link to post Share on other sites
richellis 0 Posted June 15, 2005 Report Share Posted June 15, 2005 leave it in. if you hit somthin or somthin hits you youll wish it was there! Link to post Share on other sites
dubloke 4 Posted June 15, 2005 Report Share Posted June 15, 2005 Also by disconnecting the battery there is less chance of you getting a airbag warning light upon refitting! the airbag warning light will come on no matter if you disconnect the battery, cross your legs or play hide and seek if replacing with an aftermarket wheel. unless you use a suitable resistor in place of the airbag one or you take the bulb out, which will be an mot failure next time round! good luck! Link to post Share on other sites
