need anything? breaking mk3 vr6 golf!
parts left from BREAKING my VR6 golf 2.8. drivers side driveshaft, needs new inner cv joint £10, 5 stud hubs £10 each, newish crank sensor £10, new clutch (covered 500 miles) with used pressure plate £15, power steering rack £20, power steering pump £10, power steering bracket £10, alternator bracket £10, dizzy £10, new HT heads and dizzy cap £10, power steering pulley £10, vr6 95k gearbox, no master cylinder or bracket £70, thermostat housing with new blue sensor and brand new thermostat £10, vr6 rear axle with no stubs £15, vr6 front subframe £15, full lock set with key and adjustable column £15, steering rack uj joint £10, nice rear smoked lights £10, fully working sunroof with motor £15, vr6 / gti catalytic converter, passed MOT on emmissions test and its not shattered internally £20 (scrap value), vr6 genuine vw radiator no leaks £10, genuine front bumper impact bar dated 2005 £10, various vr6 water hoses £10 each, early obd1 vr6 intake pipe to throttle body with two 6 pin untested maf sensors £10 the lot, vr6 fuel lines with fuel filter housing £20, vr6 fuel pump £20, vr6 / gti fuel tank for mk2 conversions £30, interior wiring loom, fuel pump wiring loom is missing, comes with electric window loom attached £15, fuse box with some relays £10. ignition coil £5, obd1 engine harness loom, missing a plug £10, polished obd1 inlet manifold with throttle body £30, auxillery water pump bracket £5, genuine heater matrix £5, rear engine bracket £10, gearbox bracket £10, aerial loom £5, seat brackets cut out for putting mk3 seats into a mk2 £20, early mk3 golf vr6 engine lighting loom which is seperate from the engine loom, makes it 20 times easier for conversions instead of splitting the loom £20, early ABS pump £20, nice textured white rear bumper, comes with free front bumper that has minor damage £10, sill bodykit covers x3 £5, vr6 throttle cable £5, drivers side 3 and 5 door window regulator £20, brake servo with abs sensor on the bottom £10, early brake master cylinder £10, hydro brake reservoir £5, front wiper motor £5, dashboard £5, dash bar with earths £5, mfa wiper stalks £5, rear wiper motor £5, various other interior bits £5 each. LOCATED BROMLEY IN KENT, SOUTH LONDON, i can post parts with a courier, 07773114069 is my number :-)
Edited by paceo
Do you still have the coil overs ? What make are they ?
Decent condition ?
the coilovers are made by JOM, still have the reciept dated april 2013 so i believe they are in warranty still, the car has been off the road since may 2014 so they have had just over a years use! just need to buy some c-spanners off ebay which are a few quid and thats it :-)
Sorry i didn't see this reply till now :/ - app crashed on my phone :/
I have some now but thank you for replying :)
