motorrob 15 Posted February 6, 2015 Report Share Posted February 6, 2015 I recently been to a dyno day, wondering what power my car was actually running i decided to put her on. Before i bought the car i know it had a hard life of the previous owner and decided to change this, i did everything it needed from servicing it to even putting fresh leather seats in and buffing it up. Plus many more bits and pieces. My car has done 118000 miles so well bed in She ran 181hhp which for the age and mileage thought was ok.In the book it says 204 hpHow can i get my power back? Or is it not worth trying cheers. Link to post Share on other sites
Mk3highline 287 Posted February 7, 2015 Report Share Posted February 7, 2015 The torque looks ok up to 4500k I think it drops off too soonIt the inlet change over working as it should? Check the front right hand side of the inlet see if you can move by hand Link to post Share on other sites
motorrob 15 Posted February 8, 2015 Author Report Share Posted February 8, 2015 Ive checked this, it moves with my hand. I also got a friend to rev it while i watched it. It opens up Link to post Share on other sites
Mk3highline 287 Posted February 8, 2015 Report Share Posted February 8, 2015 (edited) OkWhat spec is the car in the sense of filter exhaust etcLast service has the maf been changed cleanedBut it does seem like the change over is staying closed I think it is possible to strip the inlet manifold and take out the barrel Edited February 8, 2015 by Mk3highline Link to post Share on other sites
motorrob 15 Posted February 8, 2015 Author Report Share Posted February 8, 2015 It has a neuspeed cone type filter on (sounds awsome) i still have the standard airbox with a k&n panel filter in somewhere in garage. Exhaust is standard.maf sensor to my knowledge hasnt been changed.still original unit. Link to post Share on other sites
Mk3highline 287 Posted February 9, 2015 Report Share Posted February 9, 2015 I'm still 95% sure it has something to do with the inlet change over as @ 4800rpm the torque drops and it is ment to climb slightly Get it on vagcom and possibly to do a throttle body alignment after you have cleaned the throttle body that might help??Do the usual and check the breathers and vac pipes? Link to post Share on other sites
motorrob 15 Posted February 9, 2015 Author Report Share Posted February 9, 2015 Weekend job i think, ill haveva play at weekened and let you know the turn out, cheers for all your reply's Link to post Share on other sites
motorrob 15 Posted February 12, 2015 Author Report Share Posted February 12, 2015 No lights on my dash but plugged her in anyway, this is what came up.i deleted it and will re-check tomorrow to see if it has come back on.Code:17755Camshaft/crankshaft position bank 2Implausable ratio Link to post Share on other sites
Mk3highline 287 Posted February 12, 2015 Report Share Posted February 12, 2015 Good news I guess you found the problemJust don't get a cheap sensor I got a cheap cam sensor from euros and it was shitI got a Bosch one from eurocarparts click and collect and serch for a voucher/promo code Link to post Share on other sites
Mk3highline 287 Posted April 23, 2015 Report Share Posted April 23, 2015 Any update on the issues? Link to post Share on other sites
motorrob 15 Posted May 7, 2015 Author Report Share Posted May 7, 2015 Hey been ofline for a while, i carried on using my car daily, about 2 weeks ago my engine managment light came on, same fault code and few more, when erased you can here the engine tone change. Im thinking my timing chain may of stretched over time.so i have ordered both chains,new guides tensioners and rear main oil seal etc, going to tackle this on a bank holiday weekend when i have somespare time. May have quick look into camshaft upgrades and clutches/flywheels aswell. Big job brake out Link to post Share on other sites
motorrob 15 Posted May 12, 2015 Author Report Share Posted May 12, 2015 Well my timing chains,guides etc turned up today. Not long before the big job now. Just need to get hold of timing tool. And wish i couldfind some high lift cams beforehand too but struggling. Link to post Share on other sites
Mk3highline 287 Posted May 13, 2015 Report Share Posted May 13, 2015 Leave the cams lolHopefully I should have a rotrex kit coming coon Link to post Share on other sites
motorrob 15 Posted May 13, 2015 Author Report Share Posted May 13, 2015 I dont think i have time to start searching now for cams anyway, ive booked her in on the dyno aswell after ive done my chain, so will see if its made any difference. That sounds good you having couple days in garage setting all that up then. Be awsome when you have got it on Link to post Share on other sites
Sean_Jaymo 11 Posted May 13, 2015 Report Share Posted May 13, 2015 I've got a 4motion lump in my Corrado and it made pretty much the exact same power and curve as yours on a recent rolling road day at Stealth. New MAF bought it back to life. Link to post Share on other sites
Mk3highline 287 Posted May 14, 2015 Report Share Posted May 14, 2015 its proving difficult to get the mounting hardware for the big charger on a mk3The phirm do a straight bolt on kit for the mk4 platform (don't fit on the mk3 as the chassis leg is in the way)I wonder if the inlet flap stops working on top end if there is a problem? Good luck mate hopefully it's nothing serious In the timing chain kit you get the whole lot Give the MAF a clean while its off road with some electrical cleaner Link to post Share on other sites
motorrob 15 Posted May 16, 2015 Author Report Share Posted May 16, 2015 Cheers guys, ill have a check of the maf sensor. Yea i got the whole kit, my mate works for audi so managed get everything genuine from the guides to the seals. Dont want to do this job again so just going genuine parts. On other issues my steering rack failed last night . So early start this morning sorting a rack. Managed to get this on give her a wash n buff up. Heading to all types in couple hours, should be a good show. Link to post Share on other sites
Mk3highline 287 Posted May 16, 2015 Report Share Posted May 16, 2015 Looking goodThat's something my car don't get often lolHide the rust lol Link to post Share on other sites
motorrob 15 Posted May 17, 2015 Author Report Share Posted May 17, 2015 Haha you do feel better about it after a good wash. My mk3 bit rusty, i have new sills and arches ready to be welded on. Then will be mint. Think i may have sell her soon though Link to post Share on other sites
motorrob 15 Posted May 24, 2015 Author Report Share Posted May 24, 2015 Well guys fitted my new timing chain this weekend. Runs like a dream give her a test run to unphased 15she runs better than ever. Not a small job but well worth it. Fitted new dmf and clutch aswell and even painted my gearbox/transferbox while they where off. Link to post Share on other sites
Mk3highline 287 Posted May 24, 2015 Report Share Posted May 24, 2015 Results Just need to take it back to rolling road place see what's going on Link to post Share on other sites
motorrob 15 Posted May 25, 2015 Author Report Share Posted May 25, 2015 Yeah will have to carnt wait to see the results. Ill post them up when i have them. Maybe a couple week till i can get it innut will be worth it. See what other things i can do to her now Link to post Share on other sites
Mk3highline 287 Posted May 25, 2015 Report Share Posted May 25, 2015 Forced induction is the way forward lol supercharger or turbo Link to post Share on other sites
motorrob 15 Posted May 25, 2015 Author Report Share Posted May 25, 2015 I wouldnt mind having a supercharger on there i just dont have the time to do it and i like to do all the work myself on my car. Would probably have to send my car away for a week to someone. I could use my bike for work then just for a week or so. Link to post Share on other sites
Mk3highline 287 Posted May 26, 2015 Report Share Posted May 26, 2015 Stealth racing will sort something out there doing the mapping for meOnly problem with the rotrex kit I'm working on is you will lose AC Ruf do a kit have a nosey at there's? Link to post Share on other sites
