Where is the Corrado VR6 immobiliser box located?
I didn't think the donor Corrado VR6 I bought for the engine to stick in my MK3 had an immobiliser, but now the engine is in, it won't fire up and there appears to be a transponder chip in the key. Where is the immob box located? I couldn't see it anywhere and didn't remember seeing a signal ring on the ignition barrel!
The none idle was because I was using the ABV's ecu with the AAA MAF! Changed the ECU to the AAA one and it idles. Then it was bogging down and hesitating at low revs THAT turned out to be the MAF so I changed it for my spare and hey presto :D I also gave the TB a good clean out and checked the inlet elbow for cracks, ended up swapping that out as well, runs like a dream now! Test drive tomorrow :D
