Hi guys Does anybody know if the Mk4 288mm brakes are the same mounting as the mk3 ie do I need to use spacers as with the 312mm. I need to return my brakes back to 288 from 312 to refit my 15" wheels but I want to keep all the spacers and carriers.
Thanks in advance
  • 1 month later...
Just for information you need 6mm spacers to fit the mk4 288mm brakes as the discs are slightly more inward same as 312mm so if people need more wheel clearance for 15" or 16" wheels this could be an option.
So mk4 288 discs and calipers will go straight on to the mk3 without spacers, changing carriers etc? What size wheels did you have with your 312s calico? Just want to get into my head a few options when I get round to freshening up my brakes. Going to go with mk4 rears and not sure at the front
It would but I have mk4 discs on the front of mine and it doesn't need a spacer. Doesn't make sense to me either lol
I'm actually selling that set up and fitting 312's today so I shall report back!
Thanks
Edited by michael5556
I bought a set of mk4 288's to return mine to standard from 312 but I needed to use a few washers to get them to fit without stopping the disc from moving when I got hold of a mk3 disc I found the bell part that fits on the hub was deeper I would get pictures but I don't want to take them off again.
