Jamsplodge 3 Posted February 24, 2014 Report Share Posted February 24, 2014 So driving home about 30 mins ago, there was a clonking sound from front left of car (felt like the suspension), then I lost drive to wheels, engine is running fine and smooth, whilst engin running gear shifter can move in and out of gears (no clutch needed)... So I have ruled out clutch as I feel I wouldnt be able to get into gear, so then I though maybe drive shaft or gearbox? Any help advice appreciated please thanks Link to post Share on other sites
Marneus 78 Posted February 24, 2014 Report Share Posted February 24, 2014 You can put it in gear with the engine running, without using your clutch & there's no drive at all??Sounds like the gearbox has lunched itself, if it was a drive shaft it wouldn't go into gear without the clutch being pressed.... And if it was the clutch it wouldn't go into gear at all. Link to post Share on other sites
GordonC 20 Posted February 24, 2014 Report Share Posted February 24, 2014 Sounds like the gearbox has went mate same as above VR6 Loonibuggy Santa Pod 2014 ! VR6Pete 1 Link to post Share on other sites
Jamsplodge 3 Posted February 25, 2014 Author Report Share Posted February 25, 2014 That is what I thought, will have to source a new gearbox, thanks Link to post Share on other sites
Nex 17 Posted February 25, 2014 Report Share Posted February 25, 2014 Just a thought, but your selector hasn’t come loose or busted?It would explain why you can shift gear with the engine running (as it wouldn’t actually be shifting gears) and if it kicked the box in to neutral when it happen it would also explain why you have no drive. I know it is a long shot, but might be worth checking before you spend on a new box VR6Pete 1 Link to post Share on other sites
Marneus 78 Posted February 25, 2014 Report Share Posted February 25, 2014 ^^^ good call Nex, I never thought of that. Nex 1 Link to post Share on other sites
VR6Pete 1,456 Posted February 25, 2014 Report Share Posted February 25, 2014 Shift towers are quite common for failing Link to post Share on other sites
Marneus 78 Posted February 25, 2014 Report Share Posted February 25, 2014 Is it? I bet it's easier to find a new gearbox than a shift tower though lol VR6Pete 1 Link to post Share on other sites
Jamsplodge 3 Posted February 25, 2014 Author Report Share Posted February 25, 2014 (edited) Ok...a bit more info..the passenger side driveshaft is rotating, drivers side isnt??? So spin the wheels and the driveshaft rotates, select gear and try to pull off and drivers driveshaft turns but doesnt turn the wheel.. The driveshaft is making a terrible clonking noise. Seems like this is a broken driveshaft? thanks Edited February 25, 2014 by Jamsplodge Link to post Share on other sites
Nex 17 Posted February 25, 2014 Report Share Posted February 25, 2014 Might be a broken CV in which case buddy, but you could always get a driveshaft with the cv, kill 2 birds and what not, however you still shouldnt be able to shift gears with the engine running and not using the clutch Link to post Share on other sites
Jamsplodge 3 Posted February 25, 2014 Author Report Share Posted February 25, 2014 Ok so just checked agaon and no cant select gear without clutch! Nex 1 Link to post Share on other sites
Jamsplodge 3 Posted February 25, 2014 Author Report Share Posted February 25, 2014 sorted! inner CV joint had gone, replaced and working. Thanks for support and help Ickyketseddie 1 Link to post Share on other sites
Nex 17 Posted February 25, 2014 Report Share Posted February 25, 2014 glad you got it sorted dude Link to post Share on other sites
