George Lee 0 Posted January 12, 2014 Report Share Posted January 12, 2014 Just noticed me water pump is leaking. Ive read a guide on how to do it and it said take all front end of which I have, also disconnect the exhaust manifold from the cat, undo some engine mounts and jack the engine up so the pulley on the water pump comes above the chassis leg. So then its easily accessible. Is this the way to do it or has anyone got any tips or guides on doing it?? Sent from my GT-P5110 using Tapatalk Link to post Share on other sites
Reaperx 181 Posted January 13, 2014 Report Share Posted January 13, 2014 I never took the front end off mine or the exhaust but basically as you said the engine needs to be jacked up to get it passed the chassis. Just remove the airbox in my case had k+n so easily moved then undo engine mounts and jack engine up to gain access fairly easy to do. Link to post Share on other sites
Jimjon 28 Posted January 13, 2014 Report Share Posted January 13, 2014 I too didn't bother undoing exhaust, take a bit of wiggling but pump does come out. Link to post Share on other sites
Lukey. 381 Posted January 13, 2014 Report Share Posted January 13, 2014 It's entirely possible to get the engine high enough to remove the water pump without undoing anything but the engine mounts. Link to post Share on other sites
George Lee 0 Posted January 13, 2014 Author Report Share Posted January 13, 2014 Thanks for advice but managed to get it out. After grinding the bolts off that connect exhaust to cat because they where that rotten, and undoing the front engine mount I got it high enough Sent from my GT-P5110 using Tapatalk Link to post Share on other sites
