cornishvr6 52 Posted October 17, 2013 Report Share Posted October 17, 2013 Evening all, I've had a quick search on here for a post containing the correct porsche caliper part numbers but can't seem to find anything, think there used to be one somewhere.Anyway if anybody has the part no for Porsche calipers that fit that would be great, I'm after the front details not the rears that some people fit, suitable for a 312mm discs under a 17" rim.Cheers. Link to post Share on other sites
Lukey. 381 Posted October 17, 2013 Report Share Posted October 17, 2013 I thought people preferred not to use the fronts as it was a pain in the arse to find correct fitment discs and had to be 330mm, and that the turbo rears or boxster fronts can be used easier with 312mmDo you not think that just 312s would be enough? The mk3 will be a good couple of hundred kg lighter will it not? Link to post Share on other sites
cornishvr6 52 Posted October 17, 2013 Author Report Share Posted October 17, 2013 I thought people preferred not to use the fronts as it was a pain in the arse to find correct fitment discs and had to be 330mm, and that the turbo rears or boxster fronts can be used easier with 312mmDo you not think that just 312s would be enough? The mk3 will be a good couple of hundred kg lighter will it not?I'm sure with the correct adaptors and using fronts you can run the 312mm or the bigger 330/334 i think, I've heard from a few places not to run the rears on the front, I'd rather squeeze the biggest I can in there to be honest. Link to post Share on other sites
Lukey. 381 Posted October 17, 2013 Report Share Posted October 17, 2013 What about LCR brembos?I meant just normal 312 discs with the normal g54 288/312 spec callipers Link to post Share on other sites
cornishvr6 52 Posted October 17, 2013 Author Report Share Posted October 17, 2013 What about LCR brembos?Ahh yes good shout there mate, i forgot about that set up, will take a quick look on the bay of e now :-) Link to post Share on other sites
VIW28 29 Posted October 18, 2013 Report Share Posted October 18, 2013 Only seeing this now Mark. Part numbers you need are 996 351 421 & 996 351 422. Boxster fronts. I can get you hooked up with caliper adapters if you need some Make sure the middle number is 351 and not 352, 352's are rears and no good as pistons are too small. cornishvr6 1 Link to post Share on other sites
cornishvr6 52 Posted October 18, 2013 Author Report Share Posted October 18, 2013 Only seeing this now Mark. Part numbers you need are 996 351 421 & 996 351 422. Boxster fronts.I can get you hooked up with caliper adapters if you need some :)Make sure the middle number is 351 and not 352, 352's are rears and no good as pistons are too small.Thanks Gethin that helps alot, I may well be in contact, cheers Link to post Share on other sites
VIW28 29 Posted October 18, 2013 Report Share Posted October 18, 2013 No worries Link to post Share on other sites
