clutch problems!!
jumped in the car for first test run after doing chains and clutch etc and its hard to select gears, seems like the clutch is really dragging. i didnt touch the hydraulics other than to remove from the gearbox after a closer look i thinks its passing fluid slightly, i have bled it and its still the same so going to get another,now im wondering if my clutch fork was/is a bit bent, anyone had this ??
thinking back over the job im starting to doubt myself about what way i put the clutch plate in. im sure i put it in the right way, if i didnt it would literally not select gears and the pedal would feel crap, thats what ive experienced with the vans. would this be the case with the golf??
mmm its difficult to say, but if you are doubting yourself, and your confident that the slave cylinder is OK then the only thing you can do is remove the gearbox to check, the last thing you want to do is damage the clutch to the point you need a new one.
Pete
