Had my VR stood for about 6 months and the battery has gone dead flat. Problem is - none of the keys operate the locks (always used the alarm which won't work due to the flat battery!)
I thought I'd be a me to remove the grill and get to the bonnet catch. Removed the grill fine but can't get to the @*%#ing catch.
Any advice (other than breaking a window)??
Cheers
Des
When you do get round to sorting the locks you could do it cheaply and easily yourself, just get a load of the inserts and play around with them until you find the right combo for your key, they are all numbered so you would basically work out the code of your locks like ie 15273512, you can then re blade every lock to work. lemon squeezy.
