dan_a 1 Posted December 3, 2012 Report Share Posted December 3, 2012 Hi all,I wonder if I could get some advice on the following issue from the great people out there! :-)My instrument cluster lighting has suddenly stopped working. When I turn on the lights the speedo, dials etc will light up and then instantly go out!?? I have checked the fuse and it's good and eben change the light switch module to no avail.Any ideas peeps?Thanks, Dan Link to post Share on other sites
Daverse 175 Posted December 3, 2012 Report Share Posted December 3, 2012 might be a grounding issue, but i would take the cluster out and make sure the connector is plugged in well and got a good contact, that would be my first place to start looking Link to post Share on other sites
dan_a 1 Posted December 3, 2012 Author Report Share Posted December 3, 2012 Thought that might be the case. How much of a ball ache is it to remove? Was dead easy on my mk2! Link to post Share on other sites
Lukey. 381 Posted December 3, 2012 Report Share Posted December 3, 2012 Pieceapiss, remove the headlight switch, remove the same trim on the opposite side, remove the 2 revealed screws, remove steering column surround, put steering wheel all the way down, take out the black dials surround. You now have access to the clocks unit. Link to post Share on other sites
dan_a 1 Posted December 3, 2012 Author Report Share Posted December 3, 2012 Pieceapiss' date=' remove the headlight switch, remove the same trim on the opposite side, remove the 2 revealed screws, remove steering column surround, put steering wheel all the way down, take out the black dials surround. You now have access to the clocks unit. [/quote']Awesome thanks Lukey! A nice a little job for my day off on Wednesday....... Link to post Share on other sites
