vr6 obd 1 to 24v mk4
DBW throttles are full bore, where as the cable ones are ramped on the Golf and 2 stage opening on the Corrado (full bore also).
In other words, for the same pedal movement, the DBW throttles will let more air through, so are more mechanically 'responsive'.
24Vs are more responsive anyway, even without the DBW throttle. Better flowing head and all that.
In the case of the R32, high ignition advance at light throttle, high compression and an over sized throttle make it stupidly responsive!
nothing gay about dbw pedal, mine feels perfect! no lag and not to responsive, OP the engine is a straight swap apart from the electrics and exhaust down pipe, take a look at my thread on here in the corrado section for what needs to be done also check out the 24v thread on the corrado forum,
