no wheelspin.....
Just curious more than anything. It's not often I boot it off the line as I don't like to wear out clutch etc.
But when I have done I get little or no wheelspin. Dropping clutch at bout 4k rpm.
It has got new kuhmo ecsta spt ku31 on the front. Clutch doesn't slip.
Only thing I would say is it does bog down a little then build revs,
Is this pretty normal...
I can spin the wheels of both my VR's if I really want to but what is the point ? Surely if you want a fast get away then lack of wheels spinning is a good thing ?
Although if you drop the clutch at 4krpm then I would expect you to light up the tyres somewhat so you might be getting bogged down like you say.
Does it feel like it's getting bogged down ? Any other VR's around to test it against off the line ?
No unfortunately never been in another vr or along side one so its hard to tell. I think its either bogging down or its the standard suspension and old engine mounts taking all the sting out of it. An ur right I don't want to be spinning the wheels. Just weird that I couldn't even if I wanted to!
