Smokey 0 Posted July 18, 2012 Report Share Posted July 18, 2012 Good afternoon peopleI've jus recently bought a j plate vr6 with a blown gear box I've already got a replacement how hard areThese to do and where's best to start Thanks in advance Link to post Share on other sites
michael5556 247 Posted July 19, 2012 Report Share Posted July 19, 2012 wheels offdriveashafts outclutch slave cylinder with fluid so be carefullgear linkage outgearbox outdont forget too bleed your clutch when you put it all back together Link to post Share on other sites
Daverse 175 Posted July 19, 2012 Report Share Posted July 19, 2012 You'll be undoing the the front engine mount as well so put a jack underneath the engine to take the weight Link to post Share on other sites
ashmk3 0 Posted July 19, 2012 Report Share Posted July 19, 2012 There's a guide tony made in the premium members section. Becareful of the top two bolts as they are different lengths and if put the wrong way will pierce the water jacket behind it. Link to post Share on other sites
VIW28 29 Posted July 19, 2012 Report Share Posted July 19, 2012 dont forget too bleed your clutch when you put it all back togetherDon't need to disconnect the slave cylinder line, just undo the two bolts that attach the slave cylinder to the gearbox and hang it out of the way, negating the need for fluid everywhere and having to bleed it up Link to post Share on other sites
